![]() | Home > Technical (L322) > Tdv8 transmission problem |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Start with a gearbox oil and filter change, that tends to cure quite a few gearbox maladies. The problem is LR well tell you the box is sealed for life. This is complete nonsense as the service interval for a gearbox oil change is actually 50k. So if your car has done more than that (Which given the age I would imagine so), even if it doesn't cure this particular issue will help prolong gearbox life. |
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Not sure if it will fix the issue, but i am fully supportive of that ^^ and I agree that the idea of gear box oil for life is a non-sense. When I challenged a previous manufacturer (Porsche) about this, they justified it by saying the expected life of the car was 100,000 miles. There are not many Porsches that cease to exist at 100,000 miles.
Pw Member Since: 14 Mar 2021 Location: Derbyshire Posts: 7 ![]() ![]() ![]() |
Thanks for your input. I should have included in my post that I had the transmission fluid and filter changed about 6k ago. Hope it was done properly! |
Just curious, does it behave the same if you use the sport mode? I.e. when changing from 2nd to 3rd using the stick does it hesitate then? I'm not sure what this will tell us, but if it works OK in sport, then I might start to wonder if it is a software issue rather than a mechanical one. If I thought it was a software related issue, I might consider trying the gearbox in re-learn mode. I think it has a learn mode, but am not 100% sure. |
Yes it’s the same using the manual change. |
Mm. I had a little look around for "L322 slow to select gear". There is quite a bit out there to read up if you haven't already.
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
hi,
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
First thing to do would be to make sure there's no oil leaks as there's a sleeve the electrical connector locates in that can leak oil. I'd also check the oil level in the box to make sure that it's definitely right. Also, read the codes from the gearbox ECU - there might be none there but it might have something logged that'll point you in one direction or another. Start with the simple things. |
Here's the bridge seal:
Thanks everyone for your help. |
