Home > In Car Electronics (L322) > Tightening bolts on Harmon Kardon speakers! Door card off?
garyRR
Hey everyone,
Just joined on here because, I tend to get tumbleweed on rangerovers.net.
I have a 2006 3.6 facelift Vogue with the Harmon Kardon system (I believe not the top of the range system, which had the twin port Subwoofer and speakers in the rear pillars but, I could be wrong).
Over time, some of the bolts have come out of my speakers and they rattle in their panels (namely the drivers door and the Subwoofer). The Subwoofer is pretty easy to access and replace the bolts. My question is for the driver's door, it looks like the panel for the speaker just pops off without needing to remove the door card. Can anyone confirm or, do I need to remove the door card to access the speaker bolts?
Post #587281 13th Mar 2021 10:50am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I’m pretty sure it’s door cards off like on most cars. But mine is a my2010 so perhaps it is different.
Post #587291 13th Mar 2021 12:21pm
welcome to the forum Gary... Thumbs Up
we do have download links for workshop manuals in the wiki and also a pretty good search function... ... - .- -.
Post #587296 13th Mar 2021 12:50pm
NNNNNOOOOOO dont try and remove the speaker cover!!! Its part of the door card sir Thumbs Up
Post #587304 13th Mar 2021 1:23pm
garyRR
OK, understood.
I wondered, as it looks like it separates.
I will remove and add new bolts with thread seal tomorrow.
Post #587375 13th Mar 2021 8:51pm
garyRR
Subwoofer sorted. This was just needing new bolts.
The low range in the driver's door was actually suffering from coil rub. I tried to gently take this apart to grease however, the terminals inside are actually glued to the cone instead of soldered and, the glue broke.
I don't know what i'm doing at this point and judged it best to replace.
Post #587493 14th Mar 2021 11:45pm
Danwilderspin
Have a little look on here there’s lots to find but mainly infinity kappa and Mather infinity reference component speaker are 2ohm like these but the kappas certainly are woven Kevlar so have a far better longevity Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #589136 26th Mar 2021 10:52pm
garyRR
Job all done.
A new low range speaker was only £50 from the main dealer and is an easy job. I also took the liberty of replacing broken door clips whilst I had the panel off.
Post #589139 26th Mar 2021 11:07pm
