![]() | Home > In Car Electronics (L322) > Are the lighter sockets switched or permanent live 2007 3.6? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
I believe they are always live on a 2007 car. 2011 Range Rover Vogue SE 4.4 TDV8
Newstuart Member Since: 10 Jan 2020 Location: Northumberland Posts: 13 ![]() ![]() ![]() |
Thanks, I had a feeling this was the case leaving a fm Bluetooth adaptor plugged in and could still connect to it from my phone 30 minutes after locking the car |
It’s only the 2010 facelifted cars where the sockets power off.
Thanks, I’ll need to find a switched live somewhere to tap into I guess |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
this from our wiki might help,
That’s most useful thanks very much |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Pretty sure mine are switched as I’ve got no power when the ignition is off but the one in the boot is permanent live- I found this out when pumping up my tyres and had to have the ignition on before it worked- except the boot one- that worked from the off 2009 (2010 MY) 5.0 Supercharged Autobiography
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
I agree. Only the socket in the boot is permanently live, all the others in my 2007 switch on/off with ignition. |
The boot socket on mine is not permanent as I was trying to use this to test battery voltage and plugged in an extension to the outside of the car to measure voltage after shutdown and being left overnight. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
The heated steering wheel fuse is switched and because it doesn't run any sensitive equipment, is an ideal fuse to tap off (even the same applies on brand new cars).
Most of the 12V sockets appear to be "permanent" but actually turn off when the Body Control Module times out, including the one in the boot. 2015 Range Rover Autobiography 4.4 SDV8 |
See my response ‐ should give you the solution with a step by step guide. 2015 Range Rover Autobiography 4.4 SDV8 |
