Home > Technical (L405) > Anyone recognise where this little cover might be from??
I found another little bit of plastic in the car that I can't identify. It measures 60mm long and 34mm wide. Has some lugs on one side and reminds me of an AA battery housing cover or similar. I thought it might just be a random drop, but it has got a LandRover logo and number on the reverse L0346431AB and LEAR -GFFZA so may be part of the car. Its the same shiny black as other plastic bits in there, but I cant see a hole for it anywhere.
Any ideas?? Mike - MPx
Post #586611 7th Mar 2021 4:34pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
A random guess, but perhaps a cover for a seat belt reel? I think Lear make seat belts.
Post #586626 7th Mar 2021 6:04pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Do a Google search on the part number and see if that narrows it down.
Jim
Post #586663 8th Mar 2021 8:23am
i did that .....it doesnt Sad ... - .- -.
Post #586666 8th Mar 2021 8:52am
Yeah, first thing I tried too. But went back following Andy's guess and tried via LEAR who do seem to make automotive seats in Coventry so maybe possible but the trail dried up pretty quickly. Had another look around the car but couldn't get at the SB reels without serious dismantling which I'm not interested in doing so I'll just put it in the automotive junk box in the barn for now... Mike - MPx
Post #586694 8th Mar 2021 2:02pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Is it the flap behind the inside door pull unlock handle? It is curved and needs popped out to get access to the bolt behind it which keeps the door card on.
I've had the door card off our L405 recently and it could be that.
Post #586695 8th Mar 2021 2:16pm
Very good call, thanks,....but no. Same size and general shape as the rear ones although the leading edge is a slant rather than square and on mine they are matt plastic whereas this piece is shiney. Mike - MPx
Post #586701 8th Mar 2021 3:11pm
Treebor99
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
The OBD port cover? Anything can be made to work if you fiddle with it long enough (and have deep pockets|)
Current cars, 2011 FF 4.4 TVD8; Audit TT 1.8T convertible.
Post #586712 8th Mar 2021 4:48pm
dhallworth
Might be worth sending an email to Rob at Duckworths with the part numbers on it and see if he can find it in the parts catalogue.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #586942 10th Mar 2021 1:45pm
Treebore99 - Interesting in that my ODB port doesn't have a a cover - its not clear whether it should or not. On the L322 it was a fairly robust hinged cover but there's nothing like it on this L405. Do other L405s have an ODB port cover? Regardless, the hole over the port is not the same shape or size as the piece of plastic pictured above.
David - Its an idea thanks and I'll ask the question, but feels like a bit of a waste of Rob's time really just to satisfy my idle curiosity! Mike - MPx
Post #587023 11th Mar 2021 12:32pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
There is no cover over the OBD port - interestingly, in my car at least, there is a secondary location, closer to the door, where the OBD port could also be fitted... Again, not covered...
The code LEAR-GFFZA points indeed to some seat parts.
Post #587025 11th Mar 2021 12:37pm
Treebor99
Yeah, i did see it has a curve after I posted so figured it probably would be OBDB.
I like AndyS suggestion, a quick google, LEAR also make seats? could be seat belt or anywhere on / under the seats? Anything can be made to work if you fiddle with it long enough (and have deep pockets|)
Post #587027 11th Mar 2021 12:44pm
Agree it seems most likely seat or seatbelt related, but nothing visible without doing any dismantling. Mike - MPx
Post #587031 11th Mar 2021 12:59pm
Merchy
Just a thought, the piece does looks very like an OBD port cover.
Any open OBD ports could get covered in dirt etc and render them unusable.
As I understand (may be wrong ) SV vehicles are sorted in a separate JLR factory / facility, they may be using non standard components, which are not on any standard parts listings.
Post #587048 11th Mar 2021 2:09pm
