![]() | Home > Technical (L405) > Towing with LED trailer lights |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
You add a resistor across each LED to LOWER the resistance not increase it, the value you work out from the wattage of a filament bulb. BMW i3 Electric Car
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
Hmmm - I also though it was to increase it |
If resistance is low then current draw is high. LED's generally have a resistor in series to limit the current. The reduced current some cars cant detect / see it as a fail. By adding another lower value resistor across the LED (in parallel with it, not is series) the resistance of the circuit is lowered and the sensing system will be fooled into thinking a standard filament lamp is in circuit.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Yup it is one of those scenarios where it is easy to think that when the common response is to add a resistor the conclusion is that it would increase resistance.
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 ![]() ![]() ![]() |
These guys might be worth a call: https://sargentltd.co.uk/
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
We had to fit a additional sergeant module for our caravan, so frustrating that this stuff is so difficult LED trailer lights are not new. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
bosch Member Since: 20 Jan 2012 Location: Kent Posts: 18 ![]() ![]() ![]() |
Great, thanks for your help.
