Home > Technical (L405) > Knocking when cold
lawsol
Knocking when cold
Hi Guys, new onwmer of a V8 L405 Urban edition and enjoying the first 2 weeks ownership, however when cold and take just a right hand turn I get. big knocking noise that goes when warmed up!? Any ideas!?
Post #586814 9th Mar 2021 5:25pm
The RR Bandit
United Kingdom 2011 Range Rover Vogue TDV8 Zambezi Silver
I've had something very similar to this on mine (albeit is an L322).
By the time I've got it anywhere for someone to have a look at it, it has warmed up and stopped doing it haha
Can you feel the knock through the steering wheel when it happens? 2011 RR Vogue 4.4 TDV8
Post #586839 9th Mar 2021 6:45pm
lawsol
Yes absolutely..but literally happens once or twice until car indicates it’s warmed up, then disappears...very noticeable when it happens though!
Post #586842 9th Mar 2021 6:49pm
The RR Bandit
[img]https://www.fullfatrr.com/gallery/albums/userpics/21454/normal_Zelo4JArTcaWReYcAFgSjQ.jpg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/21454/normal_rjVAJlgHRc%2B5Zh6qoEwP1g.jpg[/img] 2011 RR Vogue 4.4 TDV8
Post #586845 9th Mar 2021 6:53pm
The RR Bandit
Due to me being utterly useless I don't seem to be able to upload some photos. But when I look at my top mounts under the bonnet it appears that one of them is wonky.
Might be worth having a look and checking yours as well.
If so we have a common issue... no idea how to solve it though hahaha 2011 RR Vogue 4.4 TDV8
Post #586846 9th Mar 2021 6:57pm
The RR Bandit
If you click on the 'Gallery' tab on my profile under my name you'll see what I mean. Drivers side is straight. passenger side it out of place.
I took it off and replaced it and it went back almost flush but has moved it's way back to where it was. It did temporarily make the issue better though. 2011 RR Vogue 4.4 TDV8
Post #586847 9th Mar 2021 7:00pm
lawsol
cheers! Ill take a look...hoping jsut a bush or something that expands when hot and therefore stops the knocking noise, but then cam across a thread on air psuspension valves that oculd need replacing?! so who knows
Post #586848 9th Mar 2021 7:00pm
The RR Bandit
Could be on to a winner there. I've got a slow leak on one corner. Suspected it was a bag but that does sound like it could be the case.
Do us a favour and put the URL in here for us to have a look at Thumbs Up 2011 RR Vogue 4.4 TDV8
Post #586850 9th Mar 2021 7:05pm
