Home > Technical (L322) > What connects these faults? |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
They are all electrical faults |
6th Mar 2021 3:30pm |
steve1 Member Since: 29 Jan 2018 Location: manchester Posts: 56 |
6th Mar 2021 4:47pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Try disconnecting the battery for 30minutes, reconnect and see if anything changes or gets worse. |
6th Mar 2021 5:14pm |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Steve, you say the dashboard isn’t illuminated, do you mean the digital displays or the background lighting to see the dash at night? If it’s the latter all your problems seem to be lighting related, and my guess would be the lamp control module. This module is mounted down low in the drivers footwell behind the kick panel on the right. This is also an area which can suffer water ingress through the o/s A pillar. Might be worth removing all the trims to get to the module, and checking for signs of water tracking down into the module. If that’s the case, you lighting woes can be sorted with a replacement module, but you’ll have to find and fix the source of the water leak first.
6th Mar 2021 6:26pm |
All the digital lights are on it's the background light that isn't, I'll have a look at your suggestion and keep you updated |
7th Mar 2021 11:29am |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
Early last year my SC had all sorts of electrical weirdness happening due to a faulty Lighting Control Module. A new replacement was expensive enough for my brain to have totally deleted the actual cost though.
7th Mar 2021 1:18pm |
Cheers mulcher I will check it out👍 |
7th Mar 2021 1:51pm |
Well, bizarre chain of events, I realise that the battery is usually the first port of call for on the fatty, so although the one fitted is only 2 years old I decided to return it for an exchange, swapped it outside the shop and low and behold everything back to normal, this in spite of the salesman testing the old one and saying it was ok, very pleased 😁😁 |
9th Mar 2021 6:52pm |
