![]() | Home > In Car Electronics (L405) > Screen Issue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
i had a similar problem with my 2012 westie...turned out it was low battery power, replaced battery and all was well.. ... - .- -.
FishersRR Member Since: 03 Mar 2021 Location: Kent Posts: 4 ![]() ![]() ![]() |
Thanks. Not experiencing any other starting issues. Did you?
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 245 ![]() ![]() ![]() |
The main battery or the backup battery in the head unit (if one exists). I am having trouble with my navigation initializing for 10-30 minutes prior to the map showing up. If I turn the vehicle off, it initializes again. My main battery was quite low yesterday when I bought the vehicle due to sitting on a dealer lot for six weeks. Thank you, Dan |
I’ve just pulled the fuse for the screen and put back in. The screen worked without driving the car.
Started the car this morning, screen not working and then pulled the same fuse, no luck unfortunately.
