Home > Technical (L322) > Brief knocking noise under acceleration
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Recently I noticed a knocking noise under acceleration from a standstill or low speed. It is like three or four dull knocks which sound like they are coming from the rear but they then cease as the car gets faster and I don't hear or feel them when accelerating at higher speeds. Nor do I hear them when cornering.
Any ideas what this could be?
(Front upper and lower arms were replaced in 2019.) 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #585689 28th Feb 2021 4:31pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Rear propshaft centre bearing ???? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #585727 28th Feb 2021 8:07pm
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
What AJGalaxy2012 just said. I've just had mine replaced.
Post #585735 28th Feb 2021 9:17pm
FrankRizzo
Well, the dealer called today. They say the bearings are OK but the bushes attaching the rear subframe to the car are shot and need to be replaced. I'll ask for a copy of the quote to see what work they are proposing. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #586086 3rd Mar 2021 6:25pm
Discotigger
I have the exact same symptoms, brief metallic knocking noise under hard acceleration from standstill or low speed. Thought it might be a loose heatshield catching something or possibly propshaft centre bearing, but now it could also be rear subframe bushes. Will have to get it into my indy for a look-see.
Post #586107 3rd Mar 2021 7:32pm
