Home > Maintenance & Mods (L405) > Handbrake stuck on
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Handbrake stuck on
Had it too good for too long. Wife cones home, there’s something wrong with the car. Ffs .handbrake will not disengage, had the following when reading code . Need to know how to disengage . It can drive but the handbrake is jammed on.
Naturally don’t want to damage it further .
Post #585831 1st Mar 2021 5:40pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
On the L322, there's an a mechanical Emergency Release cable in the RHS compartment in the boot. Just Pull it (Hard) & it releases the mechanism.
I assume there's something similar for the L405 ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #585837 1st Mar 2021 6:42pm
Mr Tee
I’ll need to check the handbook, cheers . Just found a thread from a couple of months back which points me in the right direction.
Post #585841 1st Mar 2021 7:21pm
knwatkins
It's under the cupholders in the front. There is a red strap which needs a good, hard tug to release it. Hope this helps.
Edit: sorry, I think this is for the gearbox actually, not the handbrake. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #585842 1st Mar 2021 7:43pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Have you tried putting it into service mode to see if it releases it? I’m sure there is no mechanical release on these as the handbrake mechanism is built into the calliper, so no cables going to it.
Post #585865 1st Mar 2021 10:18pm
Mr Tee
Yup tried that mate, does sweet fa , have checked the handbook, no manual release either. Garage is less than a mile away so will leave her in the drive until I get get it looked at.
Post #585868 1st Mar 2021 10:38pm
Fifth Horseman
Only way to manually release the parking brake is to remove the actuator from the calliper and operate the mechanism (clockwise rotation to release) in the calliper.
Landrover state you should replace the bolts that hold the actuator and o-ring between actuator and calliper if you do this.
This is detailed in the workshop manual in the wiki
Post #585883 2nd Mar 2021 7:30am
Mr Tee
Thanks mate
Post #585885 2nd Mar 2021 8:43am
Mr Tee
For reference , part number is LR036573, not handed . Get them on the bay from £29 (china) , also a motor factor down south selling for £79 or Duckworths @ £188. Amazingly , I have an identical fault on the Porsche, they want almost £500 for their servo motor.. the joys..
Post #585909 2nd Mar 2021 11:14am
