![]() | Home > Maintenance & Mods (L322) > Brake bleeding kit |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
You need a diagnostic tool like the IID or similar to bleed the brakes...
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
I'm not sure that is correct as long as I have not replaced any components in the system especially before the modulator then I will not have introduced any air to the system therefore the ECU will have no idea that any thing has changed.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1271 ![]() ![]() ![]() |
Hi Bigbo. Look up 'Gunsons Eezibleed kit'. Thing is it usually uses your spare tyre as a 'Power source'. Perhaps you could hook it up to a small compressor set on low. I've used one many years back and had good results. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic44822.html 2012 TDV8 Black Edition
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Cheapest and easiest is fitting a non-return valve to the bleed nipple which just prevents anything getting sucked back in on the up stroke of the conventional pedal bleeding process. You fit the pipe and valve and then just crack the bleed nipple and pump the pedal as you would normally without the need to stop to tighten the nipple before the return stroke. The ony downside is you can't see what's happening if you're at the pedal but generally that is not too much of an issue, wait until the fluid in the pipe is clean and clear and has no bubbles in it when you go back and look.
