Home > Technical (L322) > Dreaded water in the tyre well
Calvey
United Kingdom 2016 Range Rover Vogue SE SDV6 Carpathian Grey
l322 2012 TDv8
I have suddenly started getting water in my tyre well coming in down the nearside panel over the sat nav and parking module.
The funny thing is if I park it on the drive facing downwards -its only a small incline- I don't get any water. However if I park it facing uphill I get at lease an inch of water.
The front drain holes on the sunroof are clear but I am thinking it might be the rear drain holes that might be the problem but I haven't got a clue of how to get to them- any suggestion please?
Post #585146 25th Feb 2021 9:19am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
It could be your top boot seal failing.
A simply and, for a Range Rover, relatively cheap fix.
Jim
Post #585151 25th Feb 2021 9:54am
DrRob
Powerful UK has a YouTube video on clearing all 4 sunroof drains. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #585161 25th Feb 2021 11:28am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Exactly...
When you park back downwards water is collected around the problematic area. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #585196 25th Feb 2021 2:26pm
Calvey
Thanks DrRob. I had a look at the video and will have to check to see if the rear ones are blocked. sadly they don't show how to clear them, if they are.
Post #585282 25th Feb 2021 9:52pm
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
a quick way to rule out the sunroof drains i have used over the years is to seal the sunroof with Vaseline, it will create a watertight seal, leaves no mess if wiped down well and allows the sun roof to be opened, i did this with my D3 and it stopped all the leaks related to the sunroof then when the weather was better i sorted the issue out, if after doing this you still get water ingress its not from the sunroof drains 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #585334 26th Feb 2021 7:22am
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Check for rear top hinges of top trunk doors. I had a water leak there, undo the top nuts and put some silicon under. Wink RR HSE 4.4 2006 LPG
Post #585337 26th Feb 2021 7:55am
