Home > Technical (L322) > Stuttering After Harsh Acceleration TD6
Voguel322
2003 Range Rover Vogue Td6 Alaska White
Hello guys,
I have a Range Rover L322, year 2003 Engine Td6 (Diesel). I have a small issue that is it stutter after a harsh acceleration. Any ideas? Please Help Crying or Very sad Crying or Very sad
Note: Changed 1 Injector, crankshaft sensor, checked camshaft sensor, changed Fuel Filter, Checked the fuel pumps (Works Fine) at the mechanic garage
Post #584904 23rd Feb 2021 8:29am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Get some diagnostics on the injector values or do a leak-down test. My money is on a faulty injector as I have had the same twice before. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #584912 23rd Feb 2021 9:00am
Voguel322
Okay, will do that. Thanks
Post #584918 23rd Feb 2021 9:22am
Mr Tee
Sounds very familiar, had this many years ago, was injectors.
Post #584930 23rd Feb 2021 10:43am
wayneg
Diagnostic test equipment like iid tool, BMW IPNA, Carsoft etc will all show live values. If your garage does not have diagnostics God help you. A leak-down test is a common thing on common rail diesel to test the injectors l, do a search for lots of info on both. Stop throwing money at it, find the problem 1st 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #584931 23rd Feb 2021 11:01am
Voguel322
Okay Thanks
Post #584940 23rd Feb 2021 11:25am
Voguel322
Yep
Post #584941 23rd Feb 2021 11:25am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Hi, sorry i do not want to be right on this one!!
but with my TD6 that was the start of the end for my Gear Box!! i was told once it had failed that if i had serviced it when i got the those judders it would probably cured it and saved the box. I was consumed with fuel delivery so did not think about that.
How many miles on the car and have you ever serviced the box? they are known to be weak if not looked after with a service. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #584953 23rd Feb 2021 2:46pm
Sorry, but 'harsh acceleration' and TD6..... Rolling with laughter Rolling with laughter Rolling with laughter
Post #584997 23rd Feb 2021 6:45pm
