Home > Photos, Videos & Media > My L322 td6 ... Towing 30ft Power Cat.
mjdronfield
Mate, I went from JE Engineering remapped TD6 to 4.4 TDV8, and it’s like a different car altogether. I’m sure if you had no mechanical sympathy, you could spin all 4 wheels setting off. It pulls like a train.... limited to 130mph.
Less power than the 5.0 Supercharged of course, but more torque...
Have a drive in one if you get a chance.
When I picked mine up, I said to a mate “It’s like God shoving you” 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #584866 22nd Feb 2021 8:39pm
The limiter is slightly soft..... Whistle
The difference between the 3.6 and the 4.4 is marked, but the difference between a standard td6 and a 4.4 will be astronomical.
Even a remapped td6 wouldn’t see which way a 4.4 went, as Mark says have a go if you can, and that engine can be mapped too. Given that it makes 339hp in the sdv8 I’d say an extra 26hp is pretty safe... There is nothing that can't be fixed with a hammer😜😜
Post #584867 22nd Feb 2021 9:13pm
I can only compare the TD6 with the 3.6 and it's not just the nominal horse power difference, but also the refinement. The TD6 is horribly noisy at 4000 rpm so it's just painful to run it at that speed up a long hill with a heavy trailer. The TDV8 has enough power that it doesn't need to be run at that high an RPM, and even if you did it's a much nicer sound. It's a much better tow car than the TD6.
The extra gear ratio helps 'n all.
I can only imagine how good the 4.4 is with the 8 speed box.
Post #584870 22nd Feb 2021 9:51pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Kurt, I have had them all..... you are still towing Thumbs Up
Post #584872 22nd Feb 2021 10:45pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I tow a near two tonne caravan with my 4.4 TDV8 and it is truly awesome. The phrase "you don't know it's there" is, in my opinion, overused but in this situation it's true.
On a trip to Devon with the caravan on the back I accelerated off a roundabout uphill on a dual carriageway and I got to 80 mph when I noticed a) I was passing cars with ease and b) I had a caravan on the back!
It is a truly awesome tow car and a really lovely place to be.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #584878 23rd Feb 2021 12:19am
