Home > Technical (L322) > new oil cooler fitted under waranty smoke issue
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
So thankfully got the oil cooler replaced under warranty and the o rings replaced in the oil Pipe, the garage cleaned up what they could of the old oil in the v and down the back of the engine, i collected on Wednesday and they said it would take a while for all the old oil to burn off but how long is a while, i gave it a good run today inc some foot to the floor moments which did put a smile on my face, got back home smoke from under the bonet not billowing but it stunk, had a look underneath and its bone dry no oil etc so thats good, has anyone had there oil cooler replaced and had this if so how long before it cleared 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #584577 20th Feb 2021 4:09pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
It depends on how much you use it, took a couple of weeks on mine the oil gets all over the place.
Post #584583 20th Feb 2021 4:34pm
Furnitureman
i use it every day but only 20 min runs though, its going back in to the garage next friday to re flush the coolant there was a lot of oil in the the header tank is black, ill get then to check its still ok at the back, 2012 Range Rover Westminster 4.4 TDV8
Post #584584 20th Feb 2021 4:36pm
mjdronfield
Had to have mine flushed 4 or 5 times in the end. Took a few days for oil smell to go.
I’d give it a bit longer before you worry too much.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #584594 20th Feb 2021 5:34pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Mine took ages to get rid of the smell. I soaked it in “ chassis wash” mixed 50:50 sprayed down in the v with a garden sprayer let it soak and gently rinsed it off, all good now, paranoia can take over if your not careful!.
Post #584612 20th Feb 2021 7:24pm
DrRob
If you’re using it for 20mins each day that’s a recipe for a DPF to start giving you issues. Take it for longer trips Thumbs Up
Oil smell = whip off the engine cover and pollen filter box and see if they’ve actually fixed the leak Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #584623 20th Feb 2021 8:35pm
Furnitureman
It gets a good run at least once a week 50 + mph for at least 30mins 2012 Range Rover Westminster 4.4 TDV8
Post #584630 20th Feb 2021 9:17pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I replaced mine on Friday had a heart attack today got home from supermarket and smoke was billowing out but it smelt different Shocked ran the scanner over it and DPF had started to burn i guessed it would be it was heat generated if you get my meaning.
Been out since not enough for regen but no smelly oil!!
i am guessing over next few days and weeks it will just disappear.
To be honest from my experience there is not much you can clean up from the V as the main plate the oil cooler is mounted on and the EGR are all in the way i blasted loads of degreaser and got covered in crap blowing an airline around but that was it. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #584632 20th Feb 2021 9:26pm
