Home > Maintenance & Mods (L322) > Wiper Blades
Billie
England 2006 Range Rover Vogue 4.2 SC V8 Buckingham Blue
good on ya mate, just ordered mine, also two clips for the front, knowing my luck they will break on removal Big Cry
Post #584141 17th Feb 2021 11:57am
DrRob
I use the HQ ones off ebay. Great value for money and good quality
https://www.ebay.co.uk/itm/HQ-Windscreen-W...SwcTlbmTLq Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #584161 17th Feb 2021 2:14pm
kevinp
Hi Billie. Don't know whether you blades attatch the same as mine,[2011] but the drivers wiper clip is built into the small spolier and costs £80!!
Post #584175 17th Feb 2021 3:58pm
Billie
Wow, our 2006 clips are £7 for 2 from flea bay. 3 blades arrived today from Bolt on Bits £17.99.
Post #584296 18th Feb 2021 1:38pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Blades arrived from boltonbits, I didn't go for the Aero ones as wanted to keep original set up with spoiler. They look fine and work well. Easy fit although one of the fronts was a little narrow and locking clip wouldn't fit, needed to be splayed out and a bit and it was fine. Think rear one was the original so was in a poor state. Cleaned arms off and rubbed down and repainted. Will need another coat but it started raining. Sorry still trying to find a way to rotate photos!
 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #584331 18th Feb 2021 4:26pm
how to rotate pics in my signature.. ... - .- -.
Post #584354 18th Feb 2021 6:04pm
Ricardo Villa
Thanks Stan, will have a go! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #584359 18th Feb 2021 7:06pm
dhallworth
I ordered the HQ ones off eBay last week.
They arrived yesterday, were easy enough to fit, just remove everything from the wiper arm so you’ve got 2 holes for them to click into and job done.
Haven’t been out yet but they do seem to clear the screen nicely in the rain.
Post #584362 18th Feb 2021 7:25pm
Billie
blades
Well we done ours yesterday, quite easy.
Turn on the ignition without starting the car, turn on the rear wiper and switch key to off when in the upright position. Seconds to change. Same with the front, we put card over the screen for protection. All three came from a link on here, Boltonbits. Very Happy
Post #584665 21st Feb 2021 7:34am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Mine arrived from Boltonbits on Friday in good condition despite the postman (not my usual one, unfortunately) trying to post them through my letterbox!
I'm trying to work up the enthusiasm to actually fit them now.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #584710 21st Feb 2021 4:50pm
=dj=
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Ricardo Villa wrote:
Dunc, this is the ebay number I used eBay Item No. 231130867728. They do an Aero blade set as well which is eBay Item No. 360919244512 bit more expensive but it's an option. Boltonbits is the seller.
Thanks RJFF for tip on fitting. Mine has keyless start so I hopefully I can sort it. If fronts can be fitted as is, that's fine.
A word of caution - I ordered the Aero blade kit from Boltonbits on eBay, and apparently they are only 21" blades rather than 26"!
You can get away with shorter blades on the driver's side, but on the passenger's side too much of the window is missed by the sweep.
I'll need to buy some better ones before there are complaints! Laughing
Post #584743 21st Feb 2021 7:33pm
RRDunc
Well, I finally got around to fitting the wipers today (technically yesterday since I'm typing this at zero dark 22) and I only had a couple of minor issues.
I had to swap clips on the rear wiper because I couldn't get the new one to fit and my passenger side front wiper clip disintegrated in my hands as I removed it. New one ordered in case I need to regress.
New aero blades are the same length as the ones I took off so no issues there.
Post #584879 23rd Feb 2021 12:26am
=dj=
Ah, good to know you got the right length - sounds like they just sent me the wrong ones Rolling Eyes
I did message them about it yesterday, we’ll see what they say...
Post #584887 23rd Feb 2021 6:15am
