![]() | Home > Maintenance & Mods (L322) > Brake pads - Visual wear check |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
Hi all,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8549 ![]() ![]() ![]() |
If I had to guess I would say front but both look like they need changing, your front discs look rather worn as well, a pretty good lip round the edge...
It could just be road detritus but the marks on the wheel make it look like your front hub maybe leaking..... Pete
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
Quick tip, nearly two years ago changed all discs / pads and all hand brake parts for under £300, waited till Euro car parts had one of their holiday sales, all parts were Pagid, better than original and discs do not rust.
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
The wear sensors are on the inner pad so this is what you need to look at and also there are only sensors on the NSF brake and OSR so look at the inner pad on these wheels 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
