Home > Technical (L322) > fuel tank removal |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Info in the Workshop Manual downloadable from the wiki...
14th Feb 2021 8:08pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 738 |
thanks, i did look in Wiki but couldnt find much RR 2005 4.4 petrol
15th Feb 2021 1:24am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
RAVE has several pages on tank removal. Ron B. VK2OTC
15th Feb 2021 5:14am |
i have a fuel leak fuel dripping in front of the right rear wheel, cant see where it coming from RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
15th Feb 2021 9:36am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
That’s very unusual sir...
15th Feb 2021 9:43am |
The fill pipe runs down the front of the right rear wheel arch behind the arch shield, does it drip all the time or just after filling..? Pete
15th Feb 2021 2:05pm |
i have had the plastic cover off under the right hand side where the filler pipe goes in to the tank, cant see any thing
15th Feb 2021 8:40pm |
I would guess someone has had one of the two opening in the top of the tank open and not shut them properly, there is a rubber gasket which looks like it can be fitted both ways but in fact has a correct way round. If you totally fill the tank till the pump shuts off the petrol in the pipe will leak out the top of the tank and then petrol will splash out the tank till the level drops..
15th Feb 2021 8:47pm |
haylands i think you are wright
16th Feb 2021 2:19pm |
The rubber seal is slightly wider one side than the other, the thicker side goes upwards, there is a special tool to undo the retaining ring but a hammer and punch works if you are careful, it is a standard right hand thread... The seal is one of those that you chase around the opening thinking this will never fit, it seems too big, it will settle down and go in eventually, handy if someone else holds the filter assembly
16th Feb 2021 2:27pm |
haylands, i think you are wright RR 2005 4.4 petrol
16th Feb 2021 2:32pm |
three times i have tried to post and it would not let me
16th Feb 2021 2:36pm |
got my son to drive the car to day while i watched the fuel pump
20th Feb 2021 1:54pm |
The part you are looking at in the top of the tank is the filter, the pump is in the bottom of the tank connected to the filter with a pipe and wiring.
20th Feb 2021 2:10pm |
