Home > Technical (L322) > Red Restricted Performance |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8341 |
Good luck... Pete
15th Feb 2021 11:42am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
So back from dealer EGR valve and egr temp sensor!!
15th Feb 2021 12:14pm |
It just needed a bit of loving then, you obviously didn't spend any money on it for Valentines day and it felt neglected...
15th Feb 2021 12:22pm |
Ok so gone out again and!!!! no codes
15th Feb 2021 2:16pm |
Hopefully it's giving you a warning... see how it goes... then maybe you can do the jobs at your convenience... Pete
15th Feb 2021 2:28pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
It's almost certainly not he EGR sensor.
15th Feb 2021 3:37pm |
GGDR thanks it was the EGR valve as well as the temp sensor.
15th Feb 2021 4:18pm |
Jayk what is telling you the EGR needs doing?
15th Feb 2021 4:29pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
This sounds like the same thing that happened to my car. EGR failed due to being covered in oil because the oil cooler gaskets had not been fixed in time by the previous owner. Caused boost leak and in the end was not drivable at all.....
15th Feb 2021 5:34pm |
I had x2 cpdes 1 is the sensor which has been on ages and i read the thread on here so am not worried about it.
15th Feb 2021 7:54pm |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
If you was going to pay 1k for repairs but was also going to do the cooler your sel, so if your pretty handy with spanners save the 1k but a decent reader buy the cooler gaskets and see how you go with the egr using your new reader. |
15th Feb 2021 8:26pm |
