Home > Maintenance & Mods (L322) > Wiper Blades
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Wiper Blades
I want to replace front and rear wiper blades. I've read there are special fixings? A number offer them for the L322 so will some of these not fit? Also does the wipers have a service position? If not how do you get to them to replace especially the rear one? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #583904 15th Feb 2021 7:15pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
For front wipers https://boltonbits.co.uk/aero-flat-front-w...-l322.html
No idea about the rear, but I do know it's a swine to change.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #583906 15th Feb 2021 7:48pm
Ricardo Villa
Thanks Dunc, do you know if the rear has a special fixing? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #583918 15th Feb 2021 8:18pm
Ricardo Villa
Actually see they do a set of fronts and a rear so will go for that. Thanks for tip. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #583921 15th Feb 2021 8:30pm
RRDunc
No idea about the rear, unfortunately, but I'm watching this with interest because mine will need doing soon.
By the way, there are cheaper wipers than the ones I linked to but they come highly recommended by Jerome Andre (verydisco on here) in this month's LROI magazine.
Post #583922 15th Feb 2021 8:33pm
Ricardo Villa
Yes have seen a number of options but these look like they will fit without issues. As I said I've got a set with the rear included so no doubt will have fun fitting that! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #583935 15th Feb 2021 9:03pm
rjff
To help change the rear blade, albeit on a 12my, but should work on an 09.
Turn on the ignition without starting the car
turn on the rear wiper
pop the upper tailgate when the wiper is in a vertical position
turn off ignition
open lower tailgate (as you will shut the upper by leaning on it and then the arm parks up!!)
change blade
close both tailgate halves and the wiper goes to park.
HTH
If I find a service position for the fronts I'llpost it up, but I changed mine with them parked without trouble. Cheers
Richard
Gap IIDBT
Post #583993 16th Feb 2021 12:04pm
RRDunc
Where did you find the set with the rear included?
I'd like one of those for mine.
Post #584039 16th Feb 2021 2:45pm
Ricardo Villa
Dunc, this is the ebay number I used eBay Item No. 231130867728. They do an Aero blade set as well which is eBay Item No. 360919244512 bit more expensive but it's an option. Boltonbits is the seller.
Thanks RJFF for tip on fitting. Mine has keyless start so I hopefully I can sort it. If fronts can be fitted as is, that's fine. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #584058 16th Feb 2021 4:24pm
RRDunc
Thank you. Aero blades ordered!
Post #584059 16th Feb 2021 4:33pm
rjff
R V
Mine's keyless, I just push the start button without pushing the brake pedal.
Guess "ignition" is an old term now Smile Cheers
Richard
Gap IIDBT
Post #584065 16th Feb 2021 5:52pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Nice i got a set of Bosch from Halford and the fitting kit was wrong completely so swapped them out for normal ones. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #584084 16th Feb 2021 7:02pm
Ricardo Villa
Thanks Richard and Dunc will give it a go when the blades arrive. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #584110 17th Feb 2021 12:17am
p38arover
Australia
I replaced the rear last week. I used a blade from Allmakes P/N LR012047G
Generic no. PB-18 (18”/457mm)
Luckily, I still have the old one so I’ll take a pic of the holder and post it shortly.
For 2003 models, etc.
Turn on ignition.
Turn on rear wiper.
When the wiper is vertical, turn off the ignition. Wiper will stop.
Rotate wiper blade (in it's normal axis) and the blade will disconnect from the arm leaving behind the plastic fitting.
On each the side of the blade holder fitting is a square hole. Slip a small screwdriver in there to release the locking tab.
Slide the blade holder upward toward the top of the screen and off the hooked arm.
That was the old wiper blade.
The new one has an easy to reach tab to lift up and to slide the whole assembly off the hooked arm. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #584129 17th Feb 2021 11:09am
p38arover
Australia
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #584134 17th Feb 2021 11:37am
