Home > General > Advice please |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Buy the skateboard, I did, but only after getting the L322 out of my system.
14th Feb 2021 7:49pm |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 517 |
I too have come from a D2 (in fact I still have it) and after many months of research I went for the 4.4 TDV8.
14th Feb 2021 8:10pm |
Adrian 15 Member Since: 14 Feb 2021 Location: Norfolk Posts: 39 |
Thank you for your reply, I am still running a D2 automatic and to be honest if you get 25mpg you are doing well. I have found a couple with 40k on the clock so they are about. I will sort something out
14th Feb 2021 8:26pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Wow, from a D2 to a 4.4TDV8 will be like stepping into another dimension! Corrosion is a MASSIVE problem if looking for a keeper! Where they have lived, away from the coast and certainly not from too far “up norff” basically BMW made 322’s rot the least! Ford made 322’s are worse and then the 09> Tata built cars rot like pigs! BUT, find a good un, rust proof the dodgy areas and they should be fine!
14th Feb 2021 9:27pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8515 |
Fully agree with Craig there.
14th Feb 2021 9:53pm |
Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54 |
Wish my bmw made l322 got that message about the rot. I’ve just had to do the sills, wheel arches, front subframe and rear subframe as well as rear brake pipes. |
14th Feb 2021 11:08pm |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
We went from a d2 es premium to a 2011 l322, massive transformation they are truly superb to waft around in.
14th Feb 2021 11:15pm |
Thank you gentlemen for some great advice, I usually look after my own vehicles as I believe in preventative maintenance but the newer they are the more complicated it gets even with a diagnostic code reader.
15th Feb 2021 7:46am |
Grab the mouthwash BMW i3 Electric Car
15th Feb 2021 7:51am |
Point taken, I will keep my head down
15th Feb 2021 7:53am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 684 |
That last line Adrian is almost offensive.......a Sport?.........SPORT??? Heavens alive lad, man up!
15th Feb 2021 8:01am |
As the saying goes, one day, you’ll pull up to the traffic lights and a FFRR will be in the next lane! At that point you’ll wish you had bought the car your heart wanted... From that moment on, owning a Spert will be a little more every day!
15th Feb 2021 9:37am |
Exactly! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
15th Feb 2021 9:39am |
Not that I’m biased sir 👍🙏😷 |
15th Feb 2021 9:40am |
