Home > Technical (L322) > Trailer lighting
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Trailer lighting
Hi all
So this weekend consisted of rewiring my ifor williams ct177 trailer however I'm a bit lost at present with the led lights. I've rewired it all from one end to the other so fresh 7core wire, new junction box, and new wiring to each light.
The part I'm stuck on is the following
When you turn the indicator on left or right, it works with no trouble with the exception of the hyper flash which I expected.
Soon as I turn the side lights on and press the indicator, both indicators light up with the dipped red light and the indicator lights up on both side with a pulsing look so it's always on like the side light is always on which I can't seem to get past.
Soon as you turn the lights on manually with a battery to the plug, they all work fine so I'm guessing it's the car over powering them and keeping them on.
I've got a device called an led master. Soon as that's in place, the indicators work with no trouble but I don't have any side lights
Post #583681 14th Feb 2021 4:06pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
That's the pain with LED trailer lights.
The vehicle expects to sense tungsten bulb currents and gets confused.
The car transporter works fine, but the caravan is fitted with LEDs and caused problems.
The 'magic box' that was supposed to fool the car into thinking it could see tungsten bulbs only partially solved the problem.
I fitted dummy resistors in parallel with the LEDs and problem solved.
Eventually, manufacturers will get it sorted. (Rosy glasses in action) Forty years of progress. 1972-2012
Post #583688 14th Feb 2021 4:51pm
Bean19844
Mine was originally the normal bulb type but the trailer needed rewiring so picked up the lights as well. Sounds like that's worth a shot tho trying some resistors I guess as genuine ifor williams led lights are £280 so don't really fancy coughing that price if I can help it considering the trailer gets used maybe 5 times a year
Post #583691 14th Feb 2021 5:09pm
p38arover
Australia
If they were tungsten, I’d say you had a bad earth. I’d still check that. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #583710 14th Feb 2021 6:49pm
Bean19844
Where would a dodgy earth start from on the vehicle mate?
Post #583715 14th Feb 2021 7:33pm
Bean19844
All sorted at long last
Post #590275 4th Apr 2021 9:46pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Nice! Well done. And that is a great trailer made even better now Smile
Post #590287 5th Apr 2021 4:26am
Bean19844
Cheers mate. I'm in trying to work out if I should sell it or not tbh. Turns out the £70 ifor williams led lights was causing the issues with the Christmas tree lights so tried an amazon £20 special and it works perfect. As they say less is more so double stacked them on both sides too make it look better. Even found time to do the 4 marker lights as well so pretty happy with the results
Post #590288 5th Apr 2021 5:03am
Merchy
Cracking job Thumbs Up and you saved yourself a fortune.
That is some trailer!! if you hadn't said it was an Ifor Williams, I would have expected the maker's ID plate to have included the name Isambard. Rolling with laughter
Post #590302 5th Apr 2021 12:53pm
Bean19844
Cheers mate. I spoke to a few places and they said I'm looking at 10 hours labour to rewire it. Took me about 15 hours to do it but I was also having to go out and get parts but it's not a hard job. Just could be made a lot more easier if I had some ramps or hi lift axle stands. It's a decent trailer and it's done me well. I'm just in-between two minds of selling it or keeping it.
Post #590326 5th Apr 2021 4:45pm
