Home > Maintenance & Mods (L322) > 2002 - 2005 L322 bonnet letter spacing
TomV8
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
I wonder if I could ask some of you with 2002 - 2005 L322s to kindly measure the gap between the words “Range” and “Rover” on the bonnet?
I recently had my faded plastic bonnet lettering replaced with new LR genuine parts lettering. I got the local Bodyshop to do it, because I knew they would do a better job than me.
There was something that didn’t look quite right about it once they’d done it. I thought they may have put the two words slightly too close together. I measured the gap at 73mm:
Nicksaab kindly measured his 2004 AB LE and found a gap of 83mm.
Please could I ask a couple more of you with early L322s to check the gap between the words on the bonnet? I want to make triple-sure that the spacing is right before I order and fit some replacement lettering.
With many thanks
Tom 2004 L322 4.4 V8 Vogue Bonatti Grey
(205,500 miles and counting.......)
Post #583547 13th Feb 2021 1:08pm
88mm
If you buy one from Powerful they come with a full width mounting frame so as long as it's centered correctly it's fine, it is very easy to do yourself...
 Pete
Post #583556 13th Feb 2021 1:57pm
