Home > Technical (L322) > Looking for advice on a 4.2SC
Derek
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hi all,
Have been lurking for a while but am looking at buying a 4.2 SC in the near future. Currently drive an BMW e38 740 (which will be staying) and have not had Range Rovers before but always fancied one..
Got my eye on one which has done approx 70k miles
and had the AA do an inspection, but they have flagged some issues and am not sure if I should be concerned and walk away, or ask for a discount and try to resolve..
Basically all works well except for:
1. Adjustment of the mirror glasses dont work (although both fold in/out correctly)
2. When closing the sunroof, the auto close stops (presumably because it thinks there’s a blockage) and you have to keep pressing the button to close it.
Although these faults on the face of it dont seem massive, the diagnostics threw up a myriad of codes, which were cleared and then reoccured straight away (even before the car was roadtested) - have posted pics below. For some of the codes like DSM, PAM and LCM it almost appears that the system is testing itself as the codes are sequential?
Is this level/number of codes normal to appear and reappear after clearing, or is this extraordinary?
Should I be concerned on any of these if all appears to be working fine (except for the 2 points above)?
If these are a concern, would a specialist be able to rectify without it costing the world?
Finally, I understand that there is a significant vibration felt when driving but only at 60/70mph - any thoughts on likely culprits?
Grateful for any thoughts / insights you could share!
Derek
Post #583290 11th Feb 2021 8:36pm
Could be low voltage from the battery or, more likely, a failing BCM or lots of other things...
Personally with those and especially the vibration which could be anything from wheel balance to torque converter failure through gearbox and transfer box I'd walk away and find a better one...
Plenty out there....
Just my 2p.... Pete
Post #583296 11th Feb 2021 9:31pm
Derek
Thanks Haylands,
Battery was 12.7V and 13.8V charging so should be okay I think.
Out of interest, if you run diagnostics on your car do you expect to see many and not to reappear after clearing?
Just trying to get a feel for whether it is ‘normal’ to have a few on the go... 😬
Is there a particular reason you are thinking of the BCM (which I think lives under the passenger seat)?
My hope on the vibration is it to be a sticky brake caliper, as apparently that fits the symptoms as well.
Thanks
Post #583304 11th Feb 2021 11:13pm
mjdronfield
It’s not filling me with confidence. Low battery can cause all sorts of issues, as Pete says. Difficult to tell for certain.
The vibration, if a sticking calliper or wheel bearing will prob make the wheel more warm to the touch than the others.
Is this the only one you have looked at? Sounds like you need to find one to compare it to, so you know what feels right to you....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #583305 11th Feb 2021 11:25pm
Derek
Have had a look at a few, but a lot of dogs out there unfortunately.
This one is just perfect in terms of colour combo (silver with black piped ivory and silver painted wood, body condition, only 1 previous owner, et cetera.
Was all ready to move forward with
It until these pesky issues came up! 😑
Post #583306 11th Feb 2021 11:42pm
BCM controls most things on the car, although you will have another 20 odd ECU's...
There are usually a few faults that don't clear or cause any problems, but just a few...
I had numerous sticking brake callipers on my off roader L322 and never had a vibration...
Is this a private or dealer purchase...? Pete
Post #583315 12th Feb 2021 12:32am
Derek
Thanks, it is a dealer purchase and will have 6 months AA warranty on it, but obviously like to get it right from the start rather than get into a massive back and forth on issues - will need to see what they say price wise and whether they can offer getting it all properly diagnosed / resolved.
Dealer is not local to me, so any faults that are not resolved now would need to be resolved through by an indy under the AA warranty..
Post #583318 12th Feb 2021 1:09am
dhallworth
There's a lot of error codes for things on the front and rear of the car.
Does it have a facelift done on it? Unusual as pretty much ever bulb and every parking sensor is listed on that list of codes.
Post #583347 12th Feb 2021 11:26am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Don't forget to check just what the warranty covers, some are not worth the paper they are printed on. 2011 TDV8 Vogue SE
Post #583364 12th Feb 2021 12:29pm
Derek
Yes I was surprised as well by all the parking sensors and bulbs!
The car is completely bog standard, so no facelift or anything. I am wondering whether it could have been caused by water ingress in the cubby hole.
I am guessing if that is the cause I should steer clear?
Yes good point on the insurance and will need to look at carefully!
Thanks all
Post #583380 12th Feb 2021 1:23pm
The warranty will not pay for anything that was broken when you bought the car, also as has been said a lot are useless but even the best ones don't cover a lot of the electronics..
Unless it is VERY cheap it's just not worth it... electrical gremlins are very difficult to trace and can get very expensive, very quickly, if you pay someone to do it... and you wouldn't be on here asking if you could do it yourself...!!
Good luck Thumbs Up Pete
Post #583436 12th Feb 2021 5:42pm
Derek
Thanks all for your help on this.
Took the plunge in the end and have not been disappointed.
Vibration turned out to be sticky calliper and car has now had new discs all round and new callipers at the rear
Not sure why the AA man couldnt clear the codes but it’s had a full health check now from Land&Jag Surrey and all has been declared fine.
Very happy motoring thus far and buying accessories like sprinter jacks, bootliners and hybrid TV modules.. Very Happy
Thanks again!
Post #592721 29th Apr 2021 9:47pm
Gordo51
Canada 2008 Range Rover Supercharged 4.2 SC V8 Barolo Black
I have a 2008 full fat SC and you should not be getting a list of codes.
.I don't think I would buy it unless the dealer agreed to rectify them. Even if you get it at a low price it could be a headache to rectify them. I did not look at them however and if they relate to minor things like bulbs it might be OK if the dealer corrects the vibration. Maybe have a LR dealer or Indy look at the codes to get their opinion. There are a few things that don't work on my car like intermittent wipers but I still love it.
Post #593009 3rd May 2021 3:51am
