Home > Maintenance & Mods (L322) > Broken wheel stud on l322 |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 462 |
Hi Shawser,
10th Feb 2021 10:17pm |
Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88 |
Yeh it's a nasty one. I've been looking on you tube and seems best way is to drill it out, then replace the stud. Did think a small hole saw might do it. Drill in and cut the shoulder off. |
11th Feb 2021 6:33am |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 |
Is there room around it to fit a 'rounded bolt extractor socket' - the type that bites onto the outside with a reverse thread? Or is it deep in a recess in the wheel? |
11th Feb 2021 11:34am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
A large hammer and a long 12mm bolt. |
11th Feb 2021 11:52am |
Unfortunately the stud isn't separate from the hub. |
11th Feb 2021 1:01pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8336 |
If you have genuine wheels then your nuts should look like this...
11th Feb 2021 1:13pm |
That's a good suggestion, if (as you say) the tool will fit down the wheel 'hole'. I have a set of Irwin ones, but never found them to be much good on anything I've ever tried. I did see this video on YouTube by Project Farm (who I think brilliant BTW), demonstrating other brands with some pretty impressive results though: Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
11th Feb 2021 1:35pm |
They are aftermarket wheels. |
11th Feb 2021 2:15pm |
11th Feb 2021 2:17pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 593 |
If it was me I would split the remains of the nut. To do this I would accurately drill small holes as close together as possible starting as close to the hub bolt as possible.
11th Feb 2021 2:32pm |
Having looked at that picture, there doesn't seem to be anything left to get hold of. It's all in the taper of the wheel mounting hole.
11th Feb 2021 2:34pm |
Yip, you have to replace the hub. I'll try drilling it first. |
11th Feb 2021 3:02pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Depends how handy you are with tools I guess.
11th Feb 2021 3:40pm |
The hole saw worked. 4mm pilot hole in stud, then 20 mm hole saw. Slight enlargement to hole in the wheel, but nothing to be concerned about. |
11th Feb 2021 9:01pm |
