Home > Technical (L405) > Coolant / anti freeze |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
I’ve got the same on mine, Coolant level low popped up on dash on the day of lockdown last year, LRA recovered it to the only open dealer in the South East, they supposedly fixed it but were very cagey about what they did to fix it. Not used the car for about 6 weeks because of lockdown needed to go to the Post Office so checked the levels and noticed the coolant had dropped down to the min line again on the header tank. No sign of a leak under the car, topped it up and went out, came back and you can smell coolant but I can’t see a leak.
22nd Feb 2021 11:59pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Ah the joys of finding a slow coolant leak. My 5.0SC has one for a while. Right pain in the backside. Seems to do it more when not using it. For example a long journey of five hours at high speeds it’s fine. Leave it for a few days on the driveway and it’s low. No coolant to be seen on the floor, but it is in the middle of the V. I’m getting it fixed as it’s too cold to do it myself. But even then it’s not clear where from. The labour to chase this will become more expensive then just changing the hoses 🤣 |
23rd Feb 2021 8:04am |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 |
I had this on my 5.0. Tracing the source of the leak was challenging. Two new water pumps didn't cure it. Eventually traced to the oil cooler in the V - much more expensive but now fine. |
23rd Feb 2021 11:17am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Had this with my SDV8 - garage changed the EGR cooler under warranty but was still getting low coolant issue. Took several tests and garage return visits before they eventually diagnosed an oil cooler leak. However it should be noted that none of the Landrover garage tests highlighted or proved a leak (including dye and pressure tests) and they kept trying to reassure that there was no issue. It was only the low coolant warning and lack of coolant in the bottle and top-ups that allowed me to keep insisting they fixed it.
23rd Feb 2021 11:48am |
cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 66 |
Oil cooler and gasket diagnosed as leaking. Being replaced under warranty although the part is on back order. |
14th Jun 2021 5:35pm |
Stick Legs Member Since: 16 Sep 2021 Location: Somerset Posts: 27 |
Read with interest.
25th Nov 2021 7:55pm |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
Same problem, car has had no issues for 4000 miles then up comes “Coolant Low.”
25th Nov 2021 9:08pm |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 |
have you got the separate air conditioning in the rear? Mine had the same fault earlier this year. Turned out to be the coolant pipes that fed the rear air conditioning unit. Not the obviously place to look for a coolant leak. I only really noticed it when the puddle of coolant started to appear near the o/s rear wheel.
25th Nov 2021 9:15pm |
Yes, mines got the AC in the back. I’ve checked under the car just forward of the rear wheels and can’t see any evidence of a leak, but next week they’ll get her up on the ramp and be able to have a good look. |
25th Nov 2021 9:24pm |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 345 |
Mine had this issue, coolant leak. Nothing obvious. A few weeks later had the oil leak as well. So, new oil cooler fitted and indie reckoned one of the pipes had corroded? Well, anyway, all sorted and it wasn't hugely expensive. |
25th Nov 2021 9:47pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Problem is on ours it seemed to dry out as quickly as it leaked, it showed up on a stone cold start with the rear heating cranked right up, but even then was a fairly small leak. Land Rover assist couldn’t get it to leak on the drive, but we had photo’s etc. previously the dealer had it overnight on pressure tests etc with no fault found Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 |
25th Nov 2021 10:15pm |
My leak has been sorted. It was the oil cooler and the EGR cooler gasket, as well as a corroded pipe at the back of the engine. It took a week to fix because LR supplied my Indie with the wrong gasket twice. It seems their stock of oil cooler gaskets had been incorrectly labelled with the wrong part number.
13th Dec 2021 4:32pm |
That's brilliant.
13th Dec 2021 6:15pm |
Just for those having a coolant leak fixed.
15th Jan 2022 3:20pm |
