![]() | Home > General > First Winter in FFRR Love / Hate |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 800 ![]() ![]() |
Is it the locks or the doors that are frozen?
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
No frozen door, as mentioned it would open but then not close. Then once warmed up it would close. But when switched off and locked then it wouldn’t open anymore.
This is what I used for the rubbers, £10 well spent.
Yup I’ve got the same. That is not the issue though |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Yup had the same problem!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35609 ![]() ![]() |
this has been talked about for many years here on the forum..
Ahhh, sorry. That's ridiculous, how did it get through cold weather testing?! It's not that cold in the UK.... MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
I think Stan said it right |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
There’s a grommet on the rear of the front doors just by the door lock, I popeped that off occasionally and lobed a can of spray grease onto whatever I could hit.
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
I had the same problem yesterday. Car opened okay so set off to work with the gauge reading -13 ten miles to work and now the temp is -6 and I can't open the door to get out so I climbed over to the passenger side and that was the same so I ended up climbing out of the window and then using the close function on the remote to shut it again. Will be taking off the door card tomorrow and grease/silicone things, door seals already done. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
It is just one “thing” that needs new grease time after time to work. 11 years is long time |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
The Queens cars have their own bedrooms! None of that, out in the cold nonsense! |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
Constant problem where we are, as said many times, kettle with 70/30 boiling water sorts all these problems immediately, using product on the seals is a better long term alternative but with door not shutting kettle is the answer, everyday issue here at the moment |
