![]() | Home > Technical (L405) > 2018 L405 - Motorway Vibration |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Hi James, there is a bit more about the dreaded L405 vibration here :-
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35599 ![]() ![]() |
welcome to the forum..
AutoB2018 Member Since: 09 Feb 2021 Location: Surrey Posts: 7 ![]() ![]() ![]() |
Thanks guys. Andy does your new car suffer with it in any form ? You have the same wheels as me. Are you on Pirelli’s as well please ? I’ve had a read of that thread and am praying for a mishapen tyre !
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
They certainly don't all do that. If you have a full size spare wheel with about the same tread depth you could try changing it for each of the existing wheels in turn in case that makes a difference.
Thank you. I do have a full size spare, that’s a good idea. The car is with my local dealer now, I bought it from Marshall in Oxford who re balanced the wheels once but I’m not at all convinced they are looking hard for the fault.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 773 ![]() ![]() ![]() |
I agree that this would be a good idea to do. It's interesting you say that LR recommend not to rotate the wheels. I noticed on the L405 service sheets that they state "Refit road wheels to opposite sides of the same axle (Use anti-seize compound on spigot bore)." http://www.fullfatrr.com/gallery/albums/us...sheets.pdf I wonder if the recommendation is not swapping front to back? Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 613 ![]() ![]() ![]() |
Awkward for rotation directed tyres - front to back would be the only way then without strip off and refit. Mike - MPx
Hi James, currently on 22 inch continentals and I've not had a problem with vibration with the current car. i hope you manage to get yours sorted ![]() SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
On rotation, the handbook just has a red warning "do not rotate tyres around the vehicle", so odd that the service sheet would be inconsistent with that. See ownerinfo.landrover.com, selecting model year. Only Range Rovers since 1988 |
Update is that the technician could feel the vibration, which is positive. On checking the wheels some apparently had no weights, which I find odd but can only suppose they have fallen off. Weird.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
I've had a vibration problem on two L322s at motorway speed and both times it turned out to be a sticking rear brake calliper - worth having those checked? If they are sticking, they get hotter the faster you go which is why it's noticeable at motorway speeds and then seems to go away in town. 5.0 S/C Autobiography - now gone to pastures new.... |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Mine are vibrating heavily at 40 mph, absolutely caked with snow though , made them mega wobbly |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I had very similar experience although not with RR it was my Navara 65 - 75 mph was very uncomfortable!!
