![]() | Home > Technical (L322) > Fuel pump question |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Mine did with reduced performance and the fault for injection system displayed . |
Grafter38 Member Since: 09 Feb 2021 Location: Ipswich Posts: 6 ![]() ![]() ![]() |
I’ve replaced intank fuel pump and sender with brand new one
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 ![]() ![]() ![]() |
The answer to your original question is yes, I had secondary failure and in-tank still ran.
Hi thanks for your reply
This is the Rac report
FBH smoke might be because the mixture was terrible because pressure was low, total guess here but that says to me there's fuel in the engine bay but start is inhibited because injector rail pressure sensor flags the code, but FBH still attempts hence the smoke.
Thanks for your reply Ian G very helpful
Yes, worst case you have changed it preventitively as if its not been done it won't be far away. |
