Home > Technical (L322) > Cold Start Refusal - 2012 4.4V8 |
flexfly Member Since: 24 May 2017 Location: Hampshire Posts: 16 |
mine had a scary "gearbox fault" flash up on the dash this morning as it started before immediately clearing - I'm hoping that was low voltage too. The FBH hasn't been doing owt recently and it's felt a little slow to crank on the colder days so Halfrauds are installing a replacement battery on Friday (too cold to stand out there and fiddle with it myself and others seem to have had luck with them recently). 2012 RR Westminster TDV8
9th Feb 2021 3:58pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 346 |
If the full fats are anything like the discos as soon as the battery gets low you get gearbox faults etc flashing up and then instantly clearing when if first happened to me I almost myself but I got the battery tested and replaced these cars eat batteries with all there electronics heats seats wheels etc 2012 Range Rover Westminster 4.4 TDV8
9th Feb 2021 6:36pm |
gotters Member Since: 15 Aug 2015 Location: London Posts: 41 |
Gotta love a bit of online shopping - got the charger from Amazon and towing adaptor from link provide, both by lunchtime today - all hooked up to car and doing their thing at the moment. Can't see them doing any harm, fingers crossed they are exactly what needed. Thanks all for the advice and help, much appreciated |
10th Feb 2021 1:11pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
Possibly a red herring/ coincidence but this only takes a couple of minutes to check and is free!!
10th Feb 2021 4:17pm |
thanks for taking the effort/time to type all that text out @cass, but I've now read it all multiple times and haven't got a clue what you're actually advocating trying or what fixed a problem for you ! |
11th Feb 2021 7:42am |
Short version, it’s worth checking the gearbox P position manual release lever is correctly locked if you have starter problems. |
11th Feb 2021 8:00am |
