![]() | Home > Technical (L322) > Cold Start Refusal - 2012 4.4V8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
battery sounds like the suspect..get a drop charge test on it to find out if one or more cells are going.. ... - .- -.
gotters Member Since: 15 Aug 2015 Location: London Posts: 41 ![]() ![]() ![]() |
thanks Stan, would be disappointing if going as only a couple of years old and not really used the car anywhere near as much in last year
it looks like it will do the job but why pay that when a visit to halfords or a tyre/battery seller and they will test yours for free. ... - .- -.
good shout, heading to my local Halfords who do the tests apparently |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
i brought a charger from Ring that you can carry out loads of tests on a battery. it also reconditions a battery as well.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
What make of battery did you fit? If it's not that old, it's probably still under warranty.
thanks both, do you have links to the products you bought please, did a quick google and there seems a myriad of option
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I just connect mine up every 2 weeks (if not being used) via the towing socket adaptor for my ctek 7.0.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
I view batteries as a service item and change them as soon as I buy a car then every 2 years. £100 a year is a drop in the ocean of Rangerover running costs and is a small price to pay for some peace of mind on a car with a big engine and no means of bump starting it. |
This is the adapter we use:
thanks very much for the info and links on the CTEK stuff, will take a look at them
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
Starter motors are always suspect on 2012’s, but you would hear a “click” “thud” noise as it tried to engage.
Baltic Blue is right.
interesting, hope its not the starter motor as that was replaced just over a year ago with a different problem, this was the car not starting when warmed up after a longer run (there was resistance in the main fuse and cleaning it up sorted that out, took main dealers ages to find and went down starter motor replacement first of all).
