Home > Maintenance & Mods (L322) > Charging system fault - deep joy
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hi all, hope your all keeping well.
Well after a mainly faultless year, my car has given me a new years challenge.
Last week when we had snow,I jumped in the car and turned on everything. Clearly the alternator didn't like that, and gave me the above fault followed by restricted performance.
I didn't have chance to look at it until this weekend.
Cleared all the fault codes, but still have the above. I can see via live data that the charge current is reporting zero, and battery drain is present. Battery voltage doesn't change with revs.
I've read the posts regarding changing the alternator, and having done the belt and tensioner previously know vaguely what's required.
My questions are:
- is it generally just the alternator needs changing ?
- does the car reset itself following the battery reconnection regarding charge rates etc ?
- I'm assuming it's the diode pack on the alternator has failed. Are these available and has anyone changed just this,or tested the alternator ?
- before I order an alternator, is there anything else to check , like a specific failure point on the loom ?
Cheers all,
John. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #582767 8th Feb 2021 2:59am
TPKrugerZA
South Africa 2005 Range Rover HSE 4.4 V8 Alaska White
Did you get this solved?
It may or may not be a broken wire at the +ve terminal; there are 2 thin wires going to a plug there and they may have been damaged.
Was an issue on mine, same fault & solved by repairing wire. Damaged after battery was removed by someone else.
Post #591062 13th Apr 2021 10:22am
