Home > Technical (L405) > Deployable towbar - deploy & stow queries
pld118
Hi,
Should the 13 pin electric socket that deploys with the towbar deploy fully or do you have to finish the manoeuvre by hand? Pictured is where ours currently comes to rest and you can just see the spring loaded cover won’t open where it comes to rest so it then needs to be pulled down by hand to be able to open the cover (no great hardship but wanted to check:
After being manoeuvred by hand:
Finally, when stowed, is this the correct resting position for the towbar or should it be completely out of sight?
Thanks Thumbs Up
Post #559080 26th Jun 2020 7:50am
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
When I first got my car it was 2.5 years old and I don't believe the tow bar had ever been used. The socket didn't move down automatically when the bar was deployed as it was seized up and it had to be moved down by hand. This was due to lack of use and after plenty squirting of WD40 the spring mechanism loosened up and now it drops down fully when the bar is deployed.
Give it a dose of WD or similar and a manual work out and all should be good. 2017 SDV8 Autobiography
Post #559083 26th Jun 2020 8:02am
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Mine did this too after a couple of years from new...even after regular use. The fittings are just mild steel with poor corrosion protection and are exposed to the weather.
I did the same thing with WD40. 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #559095 26th Jun 2020 10:40am
The mechanism is available separately to the towing electrics so is not too badly priced... Changed plenty of them from 3yrs old! Rolling Eyes
Post #559184 27th Jun 2020 1:28am
supershuttle
Rather than start a new thread I’ll revitalise this one, my towbar doesn’t seem to want to deploy in this cold weather will liberally squirting with WD40 cut it or do I need a new mechanism for a permanent fix? Geoff
Post #582685 7th Feb 2021 1:38pm
how often do you use it Geoff?
Post #582757 7th Feb 2021 11:41pm
supershuttle
During Lockdown - never, but usually about a couple of times a month. Bike rack not towing. Geoff
Post #582765 8th Feb 2021 1:29am
Could it be frozen Geoff? I have a vision now of french lorry drivers in winter lighting bonfires 🔥 under their diesel tanks when stuck out in weather! Shocked Thud
Post #582779 8th Feb 2021 10:36am
supershuttle
It did it once before, nice warm weather, but I think I will wait a while until it gets warmer before putting my hand in my pocket, I know what will happen if I light a fire under the car Embarassed . As I say not much use during lockdown, that's why I was trying to deploy it to maintain the battery through the towing electrics using my C-tek. Stan has advised me that using the jump start points under the bonnet will be OK. Geoff
Post #582781 8th Feb 2021 10:45am
Stan ???
Post #582785 8th Feb 2021 10:58am
supershuttle
Laughing Geoff
Post #582786 8th Feb 2021 11:00am
me?
Post #582787 8th Feb 2021 11:01am
supershuttle
Thanks Stan - maybe later.
Moi? might have been better. Geoff
Post #582789 8th Feb 2021 11:17am
supershuttle
So the towbar won't reset, buttons keep on flashing buzzer keeps on sounding - methinks fuses need to be pulled. Looks like two of them any advance on two. OR Can I switch something off/reset with the IDTool?
Oh and thanks Stan - currently being tickled or should I say trickled. Geoff
Post #582856 8th Feb 2021 7:12pm
There is a reset/relearn feature Geoff, im sure it must be in the wiki somewhere sir Thumbs Up
Post #582906 9th Feb 2021 1:07am
