Home > Technical (L322) > 2012 4.4lt V8 Oil Leak Suggestions? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7803 |
When the known issue of the oil cooler leaking happens, that throws oil down into the V of the engine which normally ends up down the back and over the gearbox underneath etc.
5th Feb 2021 8:11pm |
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 |
Thanks mate. Am I right in thinking the oil coolers sit on the left too? I’ve attached a couple of pictures too. Have you ever known an oil leak on these engines to ruin an alternator?
5th Feb 2021 8:14pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8530 |
Not heard the leak cause alternator failure. That does look like it’s leaking down the back though, get the to cover off and have a look in the V at the oil cooler. It’s part of the filter housing assembly, search on here loads on swapping the seals. Doable at home but some level of risk and skill involved!
5th Feb 2021 8:54pm |
The oil cooler is in the V of the engine, so central, slightly towards the rear. It can put a lot of oil out if left, but I would have thought you’d notice the oil level drop. That said, mine had it leaking that bad when I bought it, coolant was in oil and oil in coolant.
5th Feb 2021 8:57pm |
Here was mine
5th Feb 2021 9:01pm |
6th Feb 2021 9:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4304 |
Could be a turbo leaking oil.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Feb 2021 7:43am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1215 |
If the top back of the engine is dry it could be the steering rack leaking. Mine was and looked just like your photo's. |
7th Feb 2021 8:51am |
Thanks all so much for the suggestions... I’ll have it up on the ramp again tomorrow and have a nose about.
7th Feb 2021 6:04pm |
You crack it off first and let the oil drain back into the sump before removing. Makes swapping the oil and filter a doddle. There is nothing that can't be fixed with a hammer😜😜
7th Feb 2021 6:11pm |
