Home > Maintenance & Mods (L322) > RE-PROGRAMMING LIGHT MODULE?
WHIZZ73
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Is there anyone out there that can or knows of anyone that can re-programme the light module ecu
I want to turn the side light feed off on my 2007
Any help would be welcome Razz
Post #58241 2nd Apr 2011 10:10am
why?........
you could take the side light bulbs out or take out the holder [with bulb] and secure inside engine compartment .. ... - .- -.
Post #58243 2nd Apr 2011 10:13am
WHIZZ73
I've just converted the rear lights to 2010 but with the relay in play it puts the fog light bulb warning on the dash. This is because the fog initially acts as a side and has a permanent feed. If I can re programme the light module it would eliminate the fault and I could remove the relays?
Post #58246 2nd Apr 2011 10:48am
afaik you cant do that , you can cancel light errors that appear on the dash i believe but thats about it..
pm a member who has done a conversion ,they might help...[nick h?] ... - .- -.
Post #58247 2nd Apr 2011 11:00am
dan_uk_1984
Is the LCM in the 2007 the same "type" as the early ones? I know they just upgraded the FW in them for a while. Navcoder runs on the iBus - there were some iBus legacy systems, but as the years go on there are less and less.
The workshop manual will tell you what Bus the LCM runs on, if it is iBus and you can find a place to tap into it then away you go.
I may be talking tosh though as I have no idea what systems the later models have.
D
Post #58252 2nd Apr 2011 11:17am
