Home > For Sale & Wanted > [no longer Wanted] L322 Sports Roof Bars
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
I’m looking for a set of the sports roof bars that bolt directly to the roof 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #582430 5th Feb 2021 5:09am
V8_Disco
I have been looking into this, powerful do a set that you need rails to fit, means you have to cut the trim flaps off though
Whispbar do a set that fit the hard points without having to cut those flaps, another member in hear sent me the details on the set he uses, however I am still looking as ideally I need a “though” bar - viable with whisp bar but the kayak rack I want to use the interface looks a little clunky - ideally I just want to feet as the kayak rack can be bought as with cross bars included
Rhino Do a set that mount to the hard points - but it’s rhino Australia that do that, they are not the same as the company that sells in the Uk .... “micks garage” have a set that look to bolt on but I need to look into them more
I add this as I have looked quite hard and I think your lucky if you find any of these used .... hopefully you do and ani to we set comes up as well Wink
Post #582436 5th Feb 2021 8:04am
LT
A set of L322 Roofbars are for sale on the Disco forum:
https://www.disco3.co.uk/forum/sale-ffrr-roof-bars-190610.html
Post #582445 5th Feb 2021 9:37am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I can't be certain but they look as though they're the same as mine that bolt into the existing mounting points on the roof.
Lift the plastic flap (carefully, they're fragile!), remove the blanking screw (allen key needed) and they sit in and bolt in with a M8 x 25mm bolt.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #582496 5th Feb 2021 1:55pm
Furnitureman
Hi LT I was interested in those but I thought they were the ones that went in the rails not bolted onto the car 2012 Range Rover Westminster 4.4 TDV8
Post #582520 5th Feb 2021 7:27pm
V8_Disco
I think they are the ones in the rails as well (from a quick look)
Post #582524 5th Feb 2021 7:37pm
Furnitureman
sorted got a set off ebay £62 delivered, Result 2012 Range Rover Westminster 4.4 TDV8
Post #584615 20th Feb 2021 6:48pm
