![]() | Home > Technical (L322) > dropped a clanger need advice i may have overyfilled the oil |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
My 2012 WM oil level did much the same, i.e. reading lower when cold, and also as the level is shown in segments rather than the finer level check possible with a dipstick it can seem to change more dramatically than really the case. It is also very sensitive to whether the car is exactly level or not. So if you are seeing 'max' when the oil is warm and has settled for the recommended 20 mins that would not worry me. I'd keep monitoring it, but not stop using it. It sounds as if the leak could do with attention sooner rather than later though. Only Range Rovers since 1988 |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Thanks for the reply it was fine till I put the extra oil in but when I got on the drive it stunk inside the car and then on lifting the Bonnet the burnt smoke from the back of the engine was not nice to see 2012 Range Rover Westminster 4.4 TDV8
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 410 ![]() ![]() ![]() |
Did a similar thing on our Westie. Seems fine 2+ years on.
I’m going to have a look this weekend to see if I can see where it’s coming from, 2012 Range Rover Westminster 4.4 TDV8
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
putting more oil in yours that it needs could have 'pushed' some out of the oil cooler at the rear which would cause the excess to burn and smoke.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
It is so easy to get the oil level wrong.
I tested after 30 mins then an hour and it’s at max but oil ok, I’ll take it easy to work and check the o rings 2012 Range Rover Westminster 4.4 TDV8
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
The manual seems to indicate that you should only actually add any oil if it says it’s low..... otherwise don’t.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8393 ![]() ![]() ![]() |
They found owners were not very good at checking the oil level so they design the engine to be filled to the max on a service and hopefully it will be fine until the next one, they then came out with the electronic checking and as engines were still designed as before they actually have far more oil than they need...
thanks for the replies ill remove some oil and keep an eye on the situation, going to get the oil cooler gaskets and new o rings for the other leaking pipe and sort that out then full service 2012 Range Rover Westminster 4.4 TDV8
