Home > Technical (L322) > Rear number plate light constant warning |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
Do your LED bulbs have resistors fitted to behave like normal bulbs? otherwise this error will be thrown when the car does its cold/hot checks. .
2nd Feb 2021 2:28pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 558 |
This is from the Electrical Library document
2nd Feb 2021 2:30pm |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
They've been fine for a year or more. I thought this might be the problem , so swapped them out for another two , made no difference. Did the same for the stock type of bulb and no difference. I did go through all the different sections with the code reader when I got it and didn't have any under instruments, so this is new. I guess unrelated, but this came on after I got a punctured tyre and had the tailgate open for 10-15 mins as I changed the wheel. |
2nd Feb 2021 2:41pm |
Cheers. Will do a bit of digging and see if its something cheap on eBay I can try swapping. |
2nd Feb 2021 2:46pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3967 |
Have you checked for corrosion in the bulb holders? |
2nd Feb 2021 3:48pm |
