Home > Maintenance & Mods (L322) > Td6 fuel economy |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
I don't know how you're driving, but this is what I got from my TD6. These are calculated by brimming the tank, not the indicated values, which are too optimistic. The low numbers are when I was towing. As you can see, I normally got mid to high 20's.
29th Jan 2021 7:40pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
There is a tuning box fitted to my car (cant recall the make) , found it plugged in to the ECU by accident ! Wondered why everyone said the TD6 was slow but I didn't think so ! Basically I get on average 28 mpg which includes hilly routes and a bit of spirited driving . Not bad for a 2 ton brick |
29th Jan 2021 8:56pm |
Yeah, mine had a box. Think it made an extra quoted 14 bhp. Was installed by the previous owner so I don't know how much difference it made. |
29th Jan 2021 9:50pm |
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 |
KurtVerbose I’m impressed that you work out your mpg to the nearest millimetre 😂 |
29th Jan 2021 10:27pm |
It's a bit sad isn't it.
30th Jan 2021 1:41am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Fuel economy should be improved with a good quality tuning box, but I got to admit that those bhp plus boxes look seriously old fashioned with just one measurement. Reminds me of those terrible Ebay tuning boxes where it wasn't much more that a potentio meter in a black box. With the mileage so much lower (like a 5.0SC ) I suspect it is over fuelling, a common problem with such boxes.
30th Jan 2021 7:57am |
Lipper Member Since: 02 Feb 2018 Location: Bristol Posts: 3 |
Thanks for the replies.
30th Jan 2021 9:27am |
Sounds like there's something wrong with it. |
30th Jan 2021 10:34am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Hey Bl4ckd0g interesting to hear your review on the tuning box from DTUK do you think it is worth while on my 4.4TDV8? 2012 Vogue 4.4 TDV8 - Current
30th Jan 2021 10:50am |
I agree with Kurt. Not driving it hard and getting 5.0SC fuel consumption doesn’t sound right. I would remove that tuning box first to get to a standard. And then work from there.
30th Jan 2021 4:00pm |
Lipper, my old TD6 used to avg low to mid 20s that was town driving with a bit of motorway too and when towing my caravan (Twin Axle @1700kg) i used to get 17 - 19 on a run.
30th Jan 2021 5:46pm |
I had the D40 Automatic Aventura early when it was released. So with the 2.5. I used to get iirc 21mpg. And with the DTUK box around 27mpg. Had it on the rolling road same day before and after and before it was 168Hp after 204 iirc. Really noticeable.
30th Jan 2021 7:11pm |
Bl4ckd0g that would be perfect thanks for that much appreciated 2012 Vogue 4.4 TDV8 - Current
31st Jan 2021 9:16am |
