Home > Technical (L322) > Rear drivers door will not open
Ianb4310
I’ve read several threads but none with the same symptoms!!!
My rear drivers door has suddenly stopped opening, the door popper rises and lowers with the central locking but when I pull the outer handle it moves about 2cms then no more the inner handle pulls as normal but the door doesn’t open at all!
So with the door not opening at all can I remove the door card to inspect with the door shut
Thanks
Post #581725 30th Jan 2021 10:51am
rjff
Maybe try the last post in this thread, it may be doable.
https://www.fullfatrr.com/forum/topic49477...=rear+door
If not it may be a door offf as earlier in the thread. Cheers
Richard
Gap IIDBT
Post #581741 30th Jan 2021 12:19pm
Dolphinboy
yes you can. It may be the wire inside has moved out of the holder within the handle mechanism.
Post #581743 30th Jan 2021 12:20pm
