![]() | Home > Maintenance & Mods (L322) > Battery charging |
12ty Member Since: 22 Dec 2020 Location: East Northamptonshire Posts: 14 ![]() ![]() |
I'm guessing you have a lawnmower no longer in use, good excuse to get out of that chore |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1293 ![]() ![]() ![]() |
A few weeks after I bought my car [12 months ago] my battery failed and after joining this forum I realised that the battery needed to be in tip top condition to stop all sorts of problems happening.
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
I really like the idea of the notice left on the drivers seat - CAR ON CHARGE. A long time ago I reversed out of the garage taking the cable and charger with me! I'm older now and not rushing about like I used to, but with age care is still needed.
Nice one Dave. |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
I,m cooped up with a broken leg |
Good idea. My caravan has a similar set up on the roof. Hope you legs heals quickly. |
Thanks KevinP
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 150 ![]() ![]() ![]() |
MagCode is what I installed under the bonnet. I had to install it on the driver side (LHD) because I park on the right side of my garage. Just needed some heavier wires to cross the engine compartment to the battery. Works perfect. I connect the ctek mx5 only if I have a long weekend (3 or 4 days) because of the extended use of seat- steering wheel heater und FBH during the week and short 15km drive to work.
Very neat mate. |
Nice Little Mag code install. |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Hi, my smart charger is wired permanently in the boot, its left plugged into the aux 12v cigar socket also in the boot, upon getting home I pull out the 5 ft mains cable the charger has and plug it into the weatherproof mains box mounted on house, external wall adjacent to the drive,takes seconds. I can't forget to unplug it before leaving as I have to step over cable. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
