Home > Maintenance & Mods (L322) > New owner 1st tow
Jmagg73
United States 2011 Range Rover HSE 4.4 V8 Stornoway Grey
New owner 1st tow
New guy here. 30days in on a 2011 HSE with high miles. Loving it actually. I let the wife take it today. She called... battery dead.
I don't know if a battery can die with a phone plugged in to the lighter? Anyway
We jump the battery and it seems strong but now it just keeps cranking over and over. Starts after about 8 cranks. I drive it 2 blocks and it dies. Says battery low. I crank it over a few times and it won't start. It doesn't seem like the battery at this point. Anyway..
Popped the hood... won't stay up. Is it supposed to? Look where the battery is! Damn time to call a tow.
Any guesses on the call from the shop tomorrow?
Call
Post #581334 27th Jan 2021 9:22am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
My moneys on just needing a new battery.
Post #581336 27th Jan 2021 9:29am
battery or alternator..
and yes the hood should stay up on its own... ... - .- -.
Post #581339 27th Jan 2021 9:33am
DrRob
The bonnet/hood should stay up on its own. Get new struts.
There is also the option to put the bonnet into service mode which raises it vertically to gain good access to the battery area. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581343 27th Jan 2021 9:46am
Jmagg73
Would the phone plugged into the lighter when car was off drain the battery?
On second jump attempt it wouldn't start. Just kept cranking over then stop.
Are the struts under the hood the same as the one holding up the trunk glass? Cause I think that's in need of replacing too.
Post #581346 27th Jan 2021 9:49am
Jmagg73
Any suggestions on full set of struts? Will replace back window ones also. Looks like many options.
Post #581347 27th Jan 2021 10:07am
DrRob
Powerful UK do a twin set for hood and trunk
https://www.powerfuluk.com/vehicles/range-...t-4pc.html
For USA, try Atlantic British maybe??? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581358 27th Jan 2021 10:39am
Bought these struts recently. They work ok. No idea about their long term reliability.
For the bonnet (hood): -
https://www.ebay.com/itm/2-x-YOU-S-Origina...SwM9hegryQ
Boot (trunk): -
https://www.ebay.com/itm/2-x-YOU-S-Origina...SwoPZegrwR
Using the same part numbers you might find something more local.
Fitting is a 10 minute job.
Unlikely a phone plugged into a lighter would drain a healthy battery unless you left it for weeks. These Range Rover's rely on a healthy battery, otherwise strange things happen. Easy enough to test the battery.
Post #581381 27th Jan 2021 1:22pm
Jmagg73
Turns out just the battery. Smile
Post #581574 29th Jan 2021 4:00am
Jmagg73
ok in trouble here. It's not the battery. Shop thinks its something to do with the alarm or the fob. It ran when the fob was in the cup holder area and turned off when moved. They don't have the stuff to mess with the alarm codes and say it should probably goto the LandRover Dealer shop.
they say maybe the fob is bad and the other fob I have will work.
any lifelines here? Suggestions?
Post #581636 29th Jan 2021 4:03pm
Jmagg73
oh geez. can it be that the low battery warning on the dash was the warning for a low fob battery?
Post #581643 29th Jan 2021 4:15pm
Dolphinboy
If it was the Key, it would say Key battery low.
Post #581645 29th Jan 2021 4:36pm
Jmagg73
Tried new fob. Cranking over won't start.
Post #581646 29th Jan 2021 4:43pm
Jmagg73
Off to the pros Sad
Post #581665 29th Jan 2021 7:05pm
Jmagg73
Turns out the fault codes were low pressure fuel pump circuit, and low pressure fuel sensor. They replaced the low pressure fuel sensor. Part number LR015356.
Labor and parts $587.00
Hope this may help anyone else out.
Post #582521 5th Feb 2021 7:30pm
