Home > Maintenance & Mods (L322) > Which Engine Oil
Tomc
Northern Ireland 2010 Range Rover Vogue SE TDV8 Barolo Black
Which Engine Oil
Hi everyone,
Looking for some advice please. Is Castrol Magnatec 5w30 A5 the correct oil for my RR.
2010 3.6 TDV8. I'm getting conflicting information from Euro CP and Halfords web sites.
Any help welcome.
Tom
Post #581264 26th Jan 2021 4:17pm
Gunni
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
It depends if you have a dpf. I use that oil in mine with no issues, mine is older but same engine. Jon
2009 3.6 TDV8 Vogue SE
Previous Land Rovers
Series 2 Land Rover petrol - loved it and want another
Range Rover classic v8 - loved it But glad i sold it
Series 3 Land Rover - Steering lottery But useful.
Land Rover v8 90 - Fast dirty & drank Fuel like a Boeing 737.
Post #581293 26th Jan 2021 7:54pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Which engine oil
Hi Gunni
A diesel will have a PDF filter if a UK car and the spec can be found in the manual. This is listed as SAE5W-30 AND WSS-M2C934-B. CASTROL SLX PRO POWERFLOW "C1 5W-30". There is a really good write up on here covering the oil change and some options such as Shell Oils and filters etc. Afraid that these oil references altered a bit over time but "C1" is a clue. The oil needs to be low ash re the health of the PDF
Dave
Post #581461 28th Jan 2021 9:50am
DrRob
The 3.6 is highly unlikely to have a DPF. Careful.
Use Opie Oils website as a site sponsor. Enter code "FULLFATCHAT" for some discount.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581466 28th Jan 2021 10:33am
Re: Which engine oil
Nylands wrote:
Hi Gunni
Dave
Did you mean a DPF?
The 3.6 in the UK spec didn't get a DPF sir... Standard fit came along with the 4.4 TDV8 and yes that is 100% CRITICAL you use the correct oil in the 4.4 TDV8 Thumbs Up
Post #581469 28th Jan 2021 10:41am
Nylands
My mistake as I was thinking of the 4.4v8td engine. Surprised that the 3.6 wasn't fitted with a dpf. Well spotted by the others: must get out more!
Dave
Post #581477 28th Jan 2021 11:08am
Tomc
Many thanks for the information, so in a nut shell my 3.6 has no DPF, should i use C1 type just in case or not really needed.
Thanks again.
Tom
Post #581481 28th Jan 2021 12:28pm
DrRob
Throw your rego into the Opie Oils website and it will do the rest....
Owners Manual should have the oil spec to cross reference to Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581489 28th Jan 2021 1:29pm
Dave
The 3.6 in certain market places was fitted with a DPF I believe... California springs to mind 👍
Post #581491 28th Jan 2021 1:43pm
Weegie
Thanks again.
Tom
My 3.6 doesn't have DPF . I went on the Opie website which confirmed the vehicle details of my car and recommended C1 which I am using. I went for the Millers 30W5. Am perfectly happy with it if that helps you. John
GAP iiD BT
Post #581494 28th Jan 2021 2:37pm
Tomc
Perfect. Thank you for you help everyone.
Tom
Post #581498 28th Jan 2021 2:59pm
