![]() | Home > Maintenance & Mods (L322) > Towing electrics |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
https://www.pfjones.co.uk/land-rover-range...506pf.html
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I converted mine, took about 40 minutes. Wired a new socket and mounted it on the towbar, ran the new cable into the spare wheel well. The existing cables were cut and spliced onto the new cable, easy to follow from the old wiring colours. BMW i3 Electric Car
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 250 ![]() ![]() |
Cheers guys.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
The SC that I've just bought has the twin 7 pin towing sockets on it. I want to convert that to 13 pin as well so have bought a standard 13 pin wiring loom from Rob at Duckworths Land Rover.
£150 pays for a lot of soldering, sleeves and time! BMW i3 Electric Car
It does but there are additional changes to the towing looms as well.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Lee,
With all due respect, youve done it wrong, the caravan battery will still charge, all of the signals and supplies are present in the 13 pin electrics as they are with twin 7 pin sockets.
2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
I agree with Mike on those connectors. Have a box in the garage dead easy to use, have a practice first tho so you can get the temps right before plunging into your car electrics....
Lee,
Cheers Mike , I had seen them advertised but wasn't sure.
I had a genuine LR 7N socket on the car so I bought a genuine LR 7S loom and installed it and the pins weren't the same as what you've posted above.
