Home > Technical (L322) > TD6 secondary fuel pump noise?
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hi all
Just recently the secondary fuel pump in Sylvia has become really noisy, akin to a grandfather clock ticking away in the background.
Is this a sign that it is on its way out?
Jim
Post #581192 26th Jan 2021 9:55am
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
The secondary fuel pump is driven by an electric motor so it is unlikely to make a ticking noise. When they fail they can often be restarted by giving them a knock.
Are you sure it's not the FBH Pump you can hear? This is a pulse type pump which ticks slowly,and is mounted on the subframe above the rear diff
Post #581195 26th Jan 2021 10:09am
jim4244
No, it’s definitely the secondary fuel pump under the floor of the rear seat passenger side.
Jim
Post #581220 26th Jan 2021 12:22pm
