Home > Technical (L322) > What is it and where does it go?
GrunterNI
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I was changing the air filter today and noticed that the inlet boot had come away from the side of the filter housing so I pulled the housing and headlight out as access was really tight. Whilst they were out I had a quick check about for rust or leaks and noticed this pipe hanging beside a pulley which had cut into its end cap.
I’ve had a good root about but can’t find any stubs that it should be attached to but it seems to be part of what I think is the vacuum system pipe work running over the top of the engine but there’s nothing in the service manual.
Having had a look at the photos would any of you knowledgable gents in here know what this pipe is and what or where it should be attached to?
TIA for any guidance as always Thumbs Up Current collection :
2007 Vogue TDV8 Stornoway grey, black on black
1982 JCB Sitemaster (resto)
1970 MGB
BMW R1200GS
Post #581152 25th Jan 2021 8:45pm
