Home > Technical (L322) > L322 3.0Td6 03 EGR Blanked fuel consumption
Page 3 of 3 <123
Paul thornton
I'll look at getting one of those then.
Thanks for your help.
Post #461534 20th Dec 2017 2:48pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I suggest you do Paul , no problem pal
Post #461535 20th Dec 2017 2:49pm
bostonvert
Belgium 2002 Range Rover HSE Td6 Oslo Blue
Hello, I've been reading about the td6 EGR situation as I'm sure that mine needs replacing or removing as my temp gage never seems to go above a quarter. From what I've gathered this is probably the EGR thermostat that is sticking open right?
I've already picked up a new thermostat and waterpump but I'm not 100% sure what extra parts I need to delete the EGR besides the 2 parts mentioned below?
The bungs are needed to block of the coolant lines going to the 'grey box' that you can see in front of the waterpump? It sounds very obvious but I'm coming from working on 300tdi's!
Cheers
https://www.ebay.co.uk/itm/RANGE-ROVER-L32...1553631002
https://www.ebay.co.uk/itm/BMW-EGR-COOLER-...100623.m-1
Post #580456 19th Jan 2021 2:52pm
322BLL
Estonia
If the temp gauge will not go out of blue zone, you need new gearbox cooler. Get Hella/Behr. Thermostat inside is stuck open. I assume that main thermostat is checked/changed.
Post #580651 21st Jan 2021 12:49pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Never heard of that one, Most likely the EGR thermostat then 2nd likely the engine thermostat. Easy enough to take off the EGR thermostat and see if it's stuck open. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #580701 22nd Jan 2021 2:48am
With mine it was the EGR thermostat, if I remember correctly.
Post #580705 22nd Jan 2021 7:21am
bostonvert
Strangely enough yesterday while I was driving around some small roads with steep inclines the temp gage actually went up to the middle and stayed there until I was back on the normal roads, this is the first time that that has happened since I purchased the vehicle!
Will look into the EGR delete kit and if that does't solve it guess it will be the transmission cooler
Cheers!
Post #580745 22nd Jan 2021 11:29am
322BLL
Estonia
wayneg wrote:
If the outside temp will not go under +10, you will not have this problem present. Only the coolant temp rises slower than it should.
Easy to find threads about faulty thermostats etc and keep on spending time and cash.
Common problem in bmw cars of this time.
Post #580755 22nd Jan 2021 12:57pm
Page 3 of 3 <123
