Home > Technical (L322) > Supercharged intake diameter
Danwilderspin
Don’t suppose anyone has a spare 4.2 supercharged intake they can measure? I would like to know the external diameter of the long pipe that runs from the air box plastics to the elbow I need the diameter of the elbow end circle?
Thanks! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #579985 16th Jan 2021 2:07pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I have to take mine apart, just waiting for a little better weather so if no one else is able to respond then I can measure for you.
I took this from the manual can you clarify exactly what you want measured.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #579991 16th Jan 2021 2:48pm
Danwilderspin
Thanks the end of 1 not connected to the air box thank you Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #580016 16th Jan 2021 5:08pm
bigbo
Hopefully this will help...
Sorry they are upside down, but nothing I could do following stans recent post on how to rotate photos would work. I even flipped them in Photoshop and uploaded upside down versions and they stayed upside down.
MG TF 2003
Post #580113 17th Jan 2021 1:54pm
dingg1
He wants the other end diameter, ie the inlet of the throttle body, call up a parts stockist may be the best bet
Post #580115 17th Jan 2021 2:02pm
bigbo
oh ok the Throttle body itself, not gone that far yet, just making my own smoke generator to find my leak, that may cause me to have to dismantle further, if so then I will measure. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #580116 17th Jan 2021 2:33pm
dingg1
Id estimate at 100mm but that is just a guess.
Post #580118 17th Jan 2021 2:49pm
Danwilderspin
I thing its 89mm but not sure yes the other end please if you get that far Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #580224 18th Jan 2021 11:36am
bigbo
I spent a bit of time on this today....
As I cannot do a smoke test yet I thought I could just quickly remove the Throttle Body Intake as its only held in by the rubber collar connecting it to the Throttle Body, unfortunately even with a large pry bay I cannot get it free from the collar.
So it will have to wait for me to complete a smoke test, if that shows that the collar is faulty then I will be happy to cut it off and fit a new one. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #580243 18th Jan 2021 1:27pm
Danwilderspin
I think there is a nut underneath it in the middle too to stop it moving did you get that off? then it should just need the jubilee loosening... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #580250 18th Jan 2021 1:56pm
bigbo
I cannot see any nut and its not in the manual so do you know exactly where it is and I'll have another go. Jubilee clip is loose it just feels like the rubber has stuck to the casting and I really do not want to do any damage if I can avoid it. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #580253 18th Jan 2021 2:01pm
Danwilderspin
if you look at that bottom picture you posted you can see a black circle grommet if you can you can pull the intake towards you to gt it out the grommet then you should be able to wiggle it out the back... now iirc I couldn't get it out the grommet and the grommet is on a little bracket with an 8mm nut or bolt I think so I loosed that off and it all came out... I may be making that nut bolt bit u but I seem to remember it fairly clearly Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #580254 18th Jan 2021 2:09pm
bigbo
Ok I'll have another look, certainly there was not enough movement to slide the grommet off the spigot but if its held on with a nut then I will remove that.
Fingers crossed it won't rain tomorrow. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #580255 18th Jan 2021 2:26pm
Danwilderspin
Cheers - year weather looks crap until Friday hopefully it holds off Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #580267 18th Jan 2021 3:38pm
bigbo
Had a look at RainAlarm and it showed a gap so popped out and sure enough there is a screw holding the spigot on, so many thanks for pointing that out, I don't think I would have found it. Difficult to get at with my sausage fingers and could not get a ratchet on it so open ended spanner one flat at a time.
It was still a struggle to remove the Throttle Body Intake but I hope the picture helps and that its what you are looking for.
MG TF 2003
Post #580428 19th Jan 2021 12:13pm
