Home > Technical (L322) > L322 Camera - Replacement Rear View Camera Recommendations |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 |
Just installed the one below. Good YouTube instructions and no soldering or special tools needed. Very good Picture except the camera has a narrower angle so show only the ground behind the car.
5th Apr 2020 6:18pm |
capesthorne Member Since: 12 Jan 2020 Location: Sunbury-on-Thames Posts: 11 |
Thanks for posting this, it’s taken me a while to reply, apologies.
16th Jan 2021 8:58am |
NJPovey Member Since: 29 Dec 2020 Location: Sussex Posts: 10 |
Just to add to this discussion my son helped replace the camera on my old RR when it failed. He used a drone camera, there are many good ones available and some are almost universal in that you can set PAL/NTSC aspect ratio etc. Just need the correct lens for field of view. In my installation we simply removed the old camera from the housing, cut out some of the internal plastic and the "glass" window and then mounted the new camera with sticky pads and sealed around the lens with sealant so the glass window wasn't needed. Its been good for 2 years now. An example of the type we used is here: https://hobbyking.com/en_us/foxeer-predato...black.html They come with cables so just a case of soldering the correct wires together...... 2012 L322 Westminster V8 - Current
16th Jan 2021 11:30am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Well i am really surprised at how bad RR offering is compared to my navara.
16th Jan 2021 12:24pm |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 |
JayK69,
16th Jan 2021 5:00pm |
Ischwarcz
16th Jan 2021 5:06pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
Replacement options can also be found here https://www.luxurylandroverupgrades.com/shop. His prices have gone up a fair bit since I had one off him but its far better than the original and no problems over last 4 years. |
16th Jan 2021 8:05pm |
Gordo51 Member Since: 16 Jul 2018 Location: Chilliwack Posts: 16 |
I installed the basic model from LuxuryLandRover, the one that requires you to take the old camera apart. I am not impressed. No better than the original camera except it has guide lines. Picture washed out. Next model up is same camera but already fitted in a housing so I would not buy that. Need to go for their most expensive version to get real improvement but I have not tested that one so just assuming. |
22nd Jan 2021 1:04am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
That luxury land rover upgrades shop is a shambles. Breaks so many rules and regulations I would never order from there and through there.
22nd Jan 2021 8:27am |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 |
And ridiculously expensive |
22nd Jan 2021 9:05am |
Pikey Member Since: 11 Nov 2020 Location: Cheltenham Posts: 39 |
PowerfulUK do replacement cameras, designed as a straight replacement for about £100 Pikey by name, not by nature |
22nd Jan 2021 1:30pm |
There’s a wiki to do it for about £15 |
22nd Jan 2021 1:44pm |
