Home > Maintenance & Mods (L405) > Over tightened Wheel lugs |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
You might be better off with a proper penetrating fluid, WD40 is OK but it was never designed as a penetrating fluid as such. I'd agree not to go to far with trying to get the nut undone, especially as the locking tools tend not to be the strongest. 2011 TDV8 Vogue SE |
15th Jan 2021 10:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Hot air gun or even hair dyer might work without damaging paint. |
15th Jan 2021 10:29am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8352 |
Take it down your local tyre shop, they get this all the time and are "usually" very good at getting them off...
15th Jan 2021 10:35am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
15th Jan 2021 12:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Do yourself a favour and throw the lockers in the bin sir... Buy 4 standard nuts and away you go |
15th Jan 2021 1:28pm |
Hermes Member Since: 06 Nov 2020 Location: Oop north Posts: 108 |
Agree with Craig; any thief will laugh at those locking wheel nuts....usually the only person they delay/prevent removing the wheel, is the owner
15th Jan 2021 1:34pm |
good advice new ones on order 2012 Vogue 4.4 TDV8 - Current
15th Jan 2021 1:49pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 789 |
After a tragic experience with a Volvo XC60 locker, I always replace them with plain nuts... Fun fact: Range Rover ones cost more than twice than Jaguar's! |
15th Jan 2021 1:56pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
Yep, having owned a D3 Disco where the locking wheel nut broke and just kept spinning when I was doing a wheel swap I am firmly in the “get rid of them” camp.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 770 |
^^^ This. There are many examples of the LR OEM lockers failing, resulting in a nightmare to remove and potentially damage to the wheel. Not what you want when you're at the side of the road with a flat. As per Jim's post above, one of the first jobs I also did on my L405 when I bought it was to remove the lockers and replace all the nuts as some were swollen. Also did the same on my old L320. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
15th Jan 2021 4:39pm |
In my case the problem was not the locker it was that some had well over tightened them not just the locker all of them on that wheel. In all my working on cars i have NEVER come across a wheel nut a 5ft bar would not free off it was insane.
15th Jan 2021 5:11pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
If you have this problem again try slightly tightening the other four wheel nuts to release some pressure on the tight one.
15th Jan 2021 6:33pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 |
Great advice, they’re a pain in the bum and get stuck when you least expect them to. |
15th Jan 2021 7:00pm |
